Trading Post
Discussion in 'Forum Feedback & Problems' started by spiritburner, Mar 3, 2011.
  1. spiritburner
    spiritburner Admin
    N.E. England
    I have now enabled unlimited edit time in the Trading Post.
  2. Jeff
    Hi Ross,
    Can you make it so one can delete their post in the trading post.
    Cheers,
    Jeff
  3. spiritburner
    spiritburner Admin
    N.E. England
    You can via the edit facility. Once in edit view the delete option is to the top left of your post.
  4. Jeff
  5. Chip Packard United States
    Coconut Creek FL
    How do I get access to the Trading Post. I have over 10 posts, but can still not see or access it. (Says Private)
  6. Carlsson
    You should absolutely be able to use the trading section with your more than ten posts.
    Can you try again ?
    I will tag Ross (Spiritburner-the site owner) below so he will see this.
    @spiritburner
  7. Chip Packard United States
    Coconut Creek FL
    This is what I get when I go to the trading Post.
  8. Edgar Jaime Colombia
    Colombia
    I have the same problem.
  9. Carlsson
    Very strange.
    I have contacted Ross. Just wait, and I'm sure he will have a look and explanation.
  10. spiritburner
    spiritburner Admin
    N.E. England
    Hi Chip - please check now. It should be there for.
    Unfortunately as a non-subscriber & with a post count less than 10 it will not be visible to you
    Thanks for tagging me Christer. The group promotion was not set up properly. I have corrected it & run the script to upgrade all those affected.
  11. Carlsson
    Thanks Ross. :thumbup:
  12. Greenboy23
    Greenboy23 Subscriber
    Chester
    Hi Ross,trying to take my wanted post off but have same problem, Lee
  13. Carlsson
    I can remove it for you, but I'll wait until Ross has had his saying.
    @spiritburner
  14. BigStevie
    Still unsure how to delete my posts in the Trading Post. It metions above about going in to edit. My problem is i can't find the edit button, am I daft and blind?
    Stevie
  15. Carlsson
    I can't see it either when I log in as a regular user. Something is missing.
    It's a matter for the Admin, so here comes an alert to Ross:
    @spiritburner
  16. spiritburner
    spiritburner Admin
    N.E. England
    Ok - think it's fixed. Let me know!
  17. BigStevie
    Hi Ross, Still can't see the 'Thread Tools'....
    Stevie
  18. Carlsson
    Stevie, have you checked this on your post in the trading section?
    You only get this option on threads you have started yourself, and then only on the first post you made at the very top.
  19. Tony Press
    This is what I see:
  20. Carlsson
    Thanks Tony.
    Then Ross have to look into this a bit more.
    @spiritburner
  21. BigStevie
    Still nothing I'm afraid....
  22. Carlsson
    No, you'll have to wait until Ross has checked it out again .
  23. BigStevie
    No problem, just wanted to shift the non relevant posts. Thanks, Stevie
  24. Carlsson
    I could remove it for you, but I think we'll leave it so you can try yourself once Ross has fixed the problem.
  25. WimVe
    Maybe just an idea: log out, delete cookies, and log in again ?
  26. spiritburner
    spiritburner Admin
    N.E. England
  27. Tony Press
  28. BigStevie
    Job done, thank you!
    Stevie
  29. spiritburner
    spiritburner Admin
    N.E. England
    Excellent - thanks! Not a fault as such - just a configuration I had to figure out.
