Vapalux HD44 Hand Lamp
Discussion in 'Hand Lamps' started by James, Apr 16, 2014.
  1. James
    James Subscriber
    Some of you may have seen this steel tanked Vapalux hand lamp ebay recently. The previous owner has attempted restoration but it needs repainting and the usual fettling. I would rather have an E41-style one but I will take what I find :D
  2. David Shouksmith
    :-k Hmm - wonder why my eBay Vapalux search failed to spot that one? Maybe you were just meant to have it, James... :thumbup:
  3. James
    James Subscriber
    Well it didn't hang around long :D
    Another great find James! :thumbup:
  5. David Shouksmith
    :-s :? What - was it on a BIN?
  6. James
    James Subscriber
    Yes it was a BIN.
  7. David Shouksmith
    Presumably at a price that just could not be refused... :p
  8. Neighbor Al
    Neighbor Al United States Subscriber
    Russell, PA
    Actually, the patina on it now gives it something of a steampunk appearance. I'd leave it as is just for the novelty of it.
    I envy you folks over there. Such beautiful CPLs!
  9. David Shouksmith
    Dunno about steampunk, Al, but apart from the tank which looks to have been given a coat of glossy varnish, it all seems exactly as you would expect one of these to be after 70 years... :thumbup: =P~
  10. James
    James Subscriber
    It looks like the seller used a phosphoric acid rust remover on it, leaving a black oxide, which he then varnished over. The seller included a photo from before restored it:
    http://img703.imageshack.us/img703/6613/31b6.jpg
    The lamp came to me via Italy - apparently it was left there by a British soldier during the Italian campaign of WW2.
  11. David Shouksmith
    Careless of him but probably understandable - he probably just wanted to get home!
    It seems these may have had quite an extensive use overseas. If you look at page 4 of Jim Dick's book, you'll see a Tilley publicity image showing a PL53 at the Athens Conference on Boxing Day 1944. In the image are Winston Churchill, Anthony Eden and Harold MacMillan along with Archbishop Damaskinos. What Tilley failed to mention (unsurprisingly!) is the Vapalux handlamp also doing its duty - look at the bottom edge of the photograph, just to the right of centre...
  12. James
    James Subscriber
    I repainted the steel parts and replaced the washers. One of the things I noticed when taking it apart was that there were some lead washers used. I assume these were an aftermarket replacement. Did W&B use lead washers on any of their lamps?
  13. David Shouksmith
    Nice job, James. :thumbup:
    I'm can't recall ever seeing any lead washers being used but that means nothing. I've seen red plastic NRV washers on a number of occasions. They've usually failed by now - which is perfectly understandable, of course...
  14. James
    James Subscriber
    Yes it had some red plastic washers as well.
  15. JEFF JOHNSON
    It looks great now! :thumbup:
