Vapouriser cleaning
Discussion in 'Fettling Forum' started by DP2, Oct 18, 2018.
  1. DP2
    DP2 Subscriber
    Liverpool, UK, Europe.
    I have tried cleaning several Bialaddin vapourisers using a bike brake cable with a low success rate, has anyone tries ultrasonic cleaning baths?
    Also the jet hole on many vapourisers have become enlarged resulting in overwhelming and burning outside the mantle, has anyone had any success in preening the end of the vapouriser and 're drilling the jet hole?
    Does anyone have a good drawing of a Bialaddin vapouriser, preferably an engineering drawing? I am also planning to carefully section a vapouriser to have a look at how it's constructed.
    @DP2
    Ultrasonic cleaning is ok for the last bit of cleaning your vapouriser, but mechanical and “heat and quench” is required first.
    Heat the steel of your vapouriser to dull red (don’t go mad and overheat), and drop into cold water. Tap the bottom of the vapouriser on a block of wood and let the carbon fall out. Repeat; repeat. Spray carburettor cleaner. Repeat.
    You can peen the jet, but it’s best to have a wire about 0.18mm as the guide for the jet size (rather than covering the hole completely and redrilling).
  3. DP2
    DP2 Subscriber
    I have also tried heating and quenching, will try your guide wire suggestion, Have you made some sort of tool to pain the end whilst the wire is in position and what sort of wire do you use, would have thought stainless would be good?
  4. bp4willi
    Acupuncture needles.
  5. Mackburner
    There are two patents for the Vapalux vaporiser and one by Jack Imber which I don't think was ever made. They are GB537892 and GB564870, They are pretty well identical but I assume the later one attached here will be the one mostly found on lamps today. ::Neil::
  6. DP2
    DP2 Subscriber
    Neil,
    That's great, thanks for posting, if you are attempting to fix something it's good to know its anatomy.
    David.
  7. Mackburner
    No worries. Anything for a fellow Scouser. ::Neil::
  8. DP2
    DP2 Subscriber
    I'm actually from Manchester but am married to a lovely Scouse girl.
  9. Mackburner
    Ah well I suppose someone had to live there and it is close. I'm actually a Cheshire lad from the Wirral so only almost a Scouser as well. ::Neil::
  10. DP2
    DP2 Subscriber
    That makes you a posh Scouser!
  11. TommiL
    TommiL Subscriber
    Finland
    My vapouriser cleaning method: take 0.5 - 0.75mm solid wire approx 20 cm long piece, make several small bends to the tip and attach it to drill and "drive" it clean. Additional care needed with Tilley and Vapalux/Bialaddin vapourisers jet hole side. Bit rough though, but has been working so far more severe cases. Rolling sandpaper to a long stick brings out any residual if left.
  12. Alby
    Alby Subscriber
    Hi Tommil .. and everyone ... so cleaning and restoring Tilley vapourisers , using solutions and wires , soaking leaving .. repetition .. again so on , so forth .. gas gun .. heating and quenching in fluids .. so it is a total heartbreak and a good way of getting out of the way of the wife and domestic duties ..for hours ... sometimes it works or fails ... but this particular piece of advice is SUPERB ... it the only one failsafe that actually works THANK YOU TOMMILL ..
    So today having soaked an old type Tilley vapouriser for 3 days in ATF/Acetone mix ..wired and then finding a palmfull of crappy crud that emerged .. never seen as much .. .. tested still not working .. I found in my toolbox an old v/u shaped steel galvinised peg stay .. 2 legs about 7/8 long V/U shaped .. really hard steel .. trimmed 1 leg to about 6 " and sharpened one end , by holding in my vice and filing to a very sharp point .
    So I drove it down the Vapouriser as much as I could by force ... mmm .. what ..tested it .
    littlespurts , more... and then EUREKA ... a mini spurt of 28 second kerosene .. upwards and into orbit .. great .. This particular vapouriser has defeated all my cleaning efforts for months ..but I fettled the little blighter today with TOMMILS method..
    Tested it on an unsuspecting Tilley 246A .. fired it up.. lamp is as bright as a button now...
    1 saved Vapouriser sorted ... ( old type with brass ring bottom )
    That piece of filed spring rod takes pride of place in my toolbox .. thank you TOMILL best advice ever:D/:thumbup:
  13. Alex Smith
    Midlands, UK
    @Alby Is there any chance of a photograph of the wonder tool please?
  14. Alby
    Alby Subscriber
  15. Alex Smith
    Midlands, UK
    Spot on, thank you.
  16. primaxel
    My metod for Bialaddin type:
    Demonting, cleaning with a drill the pipe max. to the pressed ring.
    Than carefully turn the spring in top of the vaporizer with the cone end of a brush etc. to clean it. Clean all parts, monting with high temperature "Ofen Dichtschnurkleber".
    Regards Frank
    image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
  17. Sellig33
    Sellig33 France Subscriber
  18. M.Meijer
    M.Meijer Subscriber
    Netherlands
    Fabelhaft!
    But I do seem to remember some brass-footed vapourisers are not threaded but swaged together, likely the later ones.
    And perhaps by W&B as well as Tilley.
