Zimbabwe Optimus 930
Discussion in '930' started by Max Stone, Oct 5, 2020.
  1. Max Stone
    Max Stone South Africa Subscriber
    South Africa
    FC9D7092-0348-4DBD-A13F-92B248D2FC43.jpeg New member here, found this Optimus 930 in a 2nd hand shop in a small town in South Africa called Port Alfred. Needed a new jet and cleaning needle which took a while to get to me. Fitted today and all working well, although the entire lamp/body gets quite hot (seems a reported feature of this model).
    Glass is makes Scott West Germany, and it had a label on the base marked “made by Optimus Zimbabwe”, with what appears to be a date (‘92). Most likely only assembled there, but interesting bit of history and I wonder if it was a Swedish African development initiative?
    Runs super quietly and gives good light with consistent pressure for hours.
    Cheers, Max
  3. Nils Stephenson
    Welcome to the forum. These Zimbabwe 930s are an interesting off shoot from the main branch. It's nice to see the original box, even though it has seen better days. I think you should take some more photos to show some of the details.
  4. Max Stone
    South Africa
    Thanks Tony, Nils,
    I’ll take some more detailed pictures and post them. And thanks Tony for the other reference thread.
    cheers, Max
  5. Fireexit1
    Welcome @Max Stone - nice lamp in good contidion.
    cheers
    Chris
  6. Max Stone
    South Africa
    4CEE4086-F54F-4B3E-8048-48AE7E70E885.jpeg 2291A440-800C-418F-8EF7-258247554A7A.jpeg D32D39D4-8904-4559-8F77-81C33B9C93D2.jpeg E4BEBB4F-BC22-42D5-903A-3961379453DF.jpeg 09327B20-CF7C-4A4B-A3BD-A67C5F467EF0.jpeg B6EBFCBD-3F77-4A0A-92EE-8979CAD9AE7A.jpeg 96A6BCF7-FF26-47E3-98BE-3FB60B15AF50.jpeg 4706BADA-578B-47B4-90FD-D09188971EF1.jpeg 341F958F-B533-45AE-9428-4E7D788C430D.jpeg 7A877141-C1A4-44FE-9D05-E3038E3C4B8C.jpeg Thanks Chris. As requested, some more detailed pics of this lamp.
  7. JEFF JOHNSON
  8. Max Stone
    South Africa
    Thanks Jeff :thumbup:
  9. BigStevie
    Welcome from the Scottish Highlands!
  10. george United States
    Welcome aboard! Nice "starter" lantern. You won't be able to stop at one! Yes, they do run hot... Haven't seen one yet that didn't.
    :content::thumbup:
  11. AussiePete
    Welcome from Queensland Australia. I’m looking forward to seeing your future posts and sharing with you.
  12. Max Stone
    South Africa
    Thanks everyone for the warm welcome, I’ll be sure to share more with the forum!
  13. Walkop Australia
    Welcome and certainly looks a strongly built lantern in excellent condition.
  14. Max Stone
    South Africa
    Thanks Walkop. The build quality is good, mostly brass. I had to order a new jet and cleaning needle. The thread on the new jet was a little shorter and the "crest" on the thread not as wide, so had a small leak on the join that I had to fix. As I'm not an expert in these lamps, I decided to use copper grease which resists high heat, which sealed the leak. I was initially worried when the lamp and tank body heated up a lot more than the couple of Colemans I have, but reading the various threads in the forum, this seems a characteristic. I can only presume that the heat from the lower part of the vapourizer tube transfers directly to the paraffin in the tank?
    As reported by Tony in another thread, Optimus Zimbabwe was formed in 1982 as a joint venture with the Swedish Government through its “Swedfund”, following independence as Zimbabwe in 1980. Not known when they closed (my lamp is 1992). The site is now used for freight and garment manufacture. I need to register on the CCS forum as there's more info about the factory there.
