Coleman 228c
Discussion in 'Pressure Lamp Discussion Forum' started by Levi Tomey, Jul 18, 2020.
  1. Alex Smith
    Central, UK
    Agreed, it is good, does the job, but hits the pocket if you are a regular user.
  2. Tom Waite
    Tom Waite United States Subscriber
    North Carolina
    Toilet bowl cleaner on all non painted parts will remove rust and other types of crud. And then a polish of your choice.
  3. Levi Tomey United States
    Muncie Indiana USA
    Man, a deer crapped on my lantern while I was camping and it started to rust. Waite, I have the answer. 73B5190B-B706-4150-99DF-7C28DEA16AB4.jpeg
  4. Pancho
    Pancho Subscriber
    México
    @Levi Tomey here is my 228C
    I also recommend you toilet bowl cleaner, fastest rust remover I’ve tried 6A3ED854-5CD9-4EBB-B41F-2F76E2874E4C.jpeg
  5. Levi Tomey United States
    Muncie Indiana USA
    Why is your fuel cap green?
  6. Levi Tomey United States
    Muncie Indiana USA
    And, is the thing in the bottom left of the screen some kind of device for lighting?
  7. Pancho
    Pancho Subscriber
    México
    came with it. I haven’t look if it’s period correct or Not.
    screen: is a Tilley preheating torch for lamps, lanterns and radiant heaters
  8. Levi Tomey United States
    Muncie Indiana USA
    I put a seal into the fuel cap today and it didn’t want to screw on to the fount at all. Any idea how to get it to go on.
  9. Pancho
    Pancho Subscriber
    México
    Did you removed the old one?
  10. Levi Tomey United States
    Muncie Indiana USA
    Didn’t see an old one. The seal is flush with the brass insert thing and there are threads available on the cap, and the cap screws on without the new seal.
  11. MYN
    Are the collars on these wartime 228s made of steel too? If they're steel, I'd guess they wouldn't be plated with nickel as what had been omitted on the founts.
    But there should be some sort of coating on them to reduce chances of rusting. Perhaps some sort of passivation such as chromated zinc plating.
    Chemicals alone would not remove those blemishes that had been leftover by heavy rust because those are already pitted. Only mechanical abrasion would smoothen them out.
    When you mentioned "flush with the brass insert", did you mean flush with the groove around the insert or flush with the entire thickness of the insert?
    If its the latter, then the seal is too thick.
  12. Levi Tomey United States
    Muncie Indiana USA
    It’s flush with the raised bit in the middle and around the side.
  13. Henry Plews
    Those seals can get very compacted over time.
    Heat the insert with a blow torch, if the old seal is there, it will expand and burn out. When the insert has cooled, clean it with wire wool and put the new seal in.
  14. MYN
    Either the old seal is still in the insert or the new seal is too thick.
  15. Levi Tomey United States
    Muncie Indiana USA
    Thanks for the help. I had no idea that the seal went inside. I thought the old seal was just the the part that I put the new seal on top of
