How Many Ways Can We Think Of That GPA's Were Used?
Discussion in 'Open Forum' started by Matty, Jan 3, 2020.
  1. Digout Australia
    Lighting: Lantern - Spot
  2. Sedgman
    Victoria, Australia
    Would a carbide lamp be a pressure lamp? :-k
  3. Sedgman
    Victoria, Australia
    Stoves - Indoor - Ranges
  4. Matty
    Queensland, Australia
    @Christer I'm using the @ because I have a few replies to do.
    Yes, I believe it is gas as in the gas that is produced from gasoline or kerosene etc. Your point that most will understand what I mean is valid and that is part of the reason I used the term GPA along with I couldn't think of an easier term to summerise what I meant.
    Yes, the torches can have specific uses. As you say some are hotbulb starters that people like me often confuse with brazing torches. This is the reason I suspect the list will be far larger than people may realise at first, many differing uses for similar appliances.
    Yes, That settles it on the fridges and fans, they are wick so should not be on the list.
    @Sedgman
    Now we are getting the hang of it. Perfect.
    Carbide lamps may operate under pressure, I'm not really sure. What I am sure of is, they don't use liquid fuel, so no, they don't qualify.
    Perfect.
    The updated list looks like this
    Heaters:
    Industrial: Leak Detection
    Irons: Clothes
    Lighting: Hollow Wire
    Lighting: Lantern - Storm.
    Lighting: Lantern - Spot.
    Lighting: Projectors - Slide.
    Lighting: Table Lamps
    Signs: Roadside - Roundabout Indicators
    Signs: Roadside - Messaging.
    Cooking: Stoves - Indoor - Range.
    Cooking: Stoves - Outdoors - Camp Stoves
    Cooking: Stoves - Industrial Plumbers Furnace (I'm open to suggestions as where to put a plumbers furnace.
    Torches: Blowlamps / blowtorches - Standard units
    Torches: Continuous soldering irons
    Torches: Brazing Units (these are much larger than blowlamps)
    Torches: Weed Killers
    Water Heaters:
    These two categories may alter if it is decided by the majority that single, double etc, ranges and camp stoves should be listed
    So, Cooking: Stoves - Outdoors - Camp Stoves, may become,
    Cooking: Stoves - Outdoors - Camp Stoves - Single Burner.
    Perhaps it may get broken down even further as such? Our stovies will need to lend some advice.
    Cooking: Stoves - Outdoors - Camp Stoves - Twin Burner - Suitcase
    I have removed the fan and fridge.
  5. Sedgman
    Victoria, Australia
    Cooking: Stoves - Outdoors - Hiking Stoves
    e.g., Svea 123, Optimus 99, MSR types
  6. Tony Press
    Pig Heater (Tilley IF 54)
    Greenhouse Heater
  7. Digout Australia
    Lighting: Lantern - Flood
  8. Matty
    I like the use of examples of manufacturers. Once we start to exhaust the more common entries I think the use of manufacturers names and even photo's or other evidence of their existence should be shown.
    For instance we can't just put a "Fruit Bat lamp" as an entry. Some type of evidence should be shown. Of course, the "Fruit Bat lamp" example is just a made up example.
    I was emailed an entry by a friend and long time lurker of CPL, Marko. Washing Machines: Aladdin, Robincraft. Australian. I've added it to the list
    Cooking: Stoves - Outdoors - Hiking Stoves: Svea 123, Optimus 99, MSR types
    Heaters: Pig Heater - Tilley IF 54
    Industrial: Leak Detection - Tilley - LD1
    Industrial: Plumbers Furnace
    Industrial: Lighting - Roadside - Roundabout Indicators: Tilley Book
    Industrial: Lighting - Signs: Roadside - Messaging: Tilley Book
    Irons: Clothes Irons
    Lighting: Hollow Wire - Ceiling Lights
    Lighting: Lantern - Flood: Tilley FL6
    Washing Machines: Aladdin - Robincraft. Australian
    Water Heaters:
  9. Matty
    I'll add a couple to keep the ball rolling until we can get up to the more unusual and and least known uses. The two I added are as follows
    Lighting: - Self Contained - Wall Lamps.
    Water Heaters: - Water - Urn - Coleman.
    I pinched this image of a Coleman urn from the web.
    [​IMG]
    Washing Machines/Boiler: Aladdin - Robincraft. Australian
  10. Mackburner
    How about these bread oven lamps? ::Neil::
  11. Matty
    Wow, aren't they special. Thanks for showing them. This is the sort of thing and many more that I feel will come out in this topic.
    I was hoping there would be more interest in the topic and more suggestions would be made. There are a lot of appliances that are well known that haven't been added to the list. I was just going to let this topic die off :)
    I need to apologise to @phaedrus42 Phil had mentioned bread ovens earlier but I somehow missed putting them in my list. I'm not sure what the Primus bread ovens look like but if it is similar to the Focus ones I will credit them both.
    As well as your bread ovens, a friend of mine Marko, kept record of an Australian made kettle appliance that sold on ebay late last year.
    Thanks to those that have participated or intend to participate.
    So two new entries: Water Heaters: Kettle - Red ball and Cooking: Ovens - Bread - Focus.
    Also I am reinstating one I somehow omitted at a later stage: Cooking: Ovens - Bread - Primus
    Heater: Kettle - Red ball
  12. Matty
    @JEFF JOHNSON I found this wick, car number plate, messaging lamp from 1912. While it isn't a pressure lamp nor will it be added to the list, I thought you might be interested.
  13. JEFF JOHNSON
    That is a neat piece of kit!:thumbup:
  14. aephilli
    Tallahassee Fla USA
    Do the guys that do hot tar and bituminous membrane roofing work just use the weed killing torches?
    I want to say I heard of an "Infrared Lantern" for something like night vision devices or signaling or night landings?
  15. JohanOptimus South Africa
    South Africa
    Domestic radiator heaters, e.g. Coleman Model 18 kerosene Radiant.
  16. Tony Press
    Locomotive headlight (FL6 - see Jim Dick’s book).
    It always struck me that they would be a pretty pathetic headlight for a locomotive.
  17. Carlsson
    Yes, I would assume that a spotlight should be more suitable for a locomotive rather than a flood light.
  18. Matty
    @JohanOptimus
    Thank you, the Coleman radiant heater has been added.
    @Carlsson
    I have a few locomotive lights I will share once we get through the easier appliances. When you get a chance, please replace the list in the opening post with the latest list from this post. Thanks.
    @aephilli
    I'm not aware of infrared lamps if you find one please add it. The only lamps I'm aware of that were used on runways are the Tilley FL6. My knowledge on the subject is minimal.
    Heaters: Home Radiant - Coleman Model 18
  19. Carlsson
    Done!
  20. Mackburner
  21. David Shouksmith
    Absolutely - but you can see bugger-all in front anyway, even during the day, because of the boiler spoiling the view ahead. My guess is that they were more to be seen rather than seeing-by and British locomotives weren't fitted with them...
  22. Matty
    Thank you. I have added a military section and added the 200A and also quoted your description as written by you in another topic on CPL. I think anyone like myself, that didn't know of the Coleman Infrared lantern, will enjoy learning why they were made and where they were deployed.
    @Carlsson, thank you for updating the list.
    I somehow deleted what I had written in response to the interesting discussion on locomotive headlights and the FL6. I couldn't be bothered writing it out again.
    Has anyone got a photo of the Primus bread ovens? Are the ovens comparable to the Focus?
    The latest list:
    Lighting: Self Contained - Wall Lamps.
    Military: Infrared Lamp - Coleman 200A Infrared Lantern - Project Diogenese was a Coleman 200A with 4 concentric globes designed to emit infrared and heat only and was used as a landing or drop zone marker during the Vietnam war. ::Neil::
  23. Matty
    Here is a fun one. A a gravity fed iron heater built into an ironing board.
  24. Wim
    Wim Subscriber
    Dendermonde, Belgium
    A very daring but also very "modern" design! Clearly fromwell before the time everyone had electric irons...
    Looks like a left-handed design to me. Probably easy to swap things around.
  25. Matty
    Wim, yes it would have been the top of the range in ironing boards back in the day :)
  26. podbros
    Those people that do the 'Extreme Ironing' might like it? :-k
    (tried to do a link but failed:()
  27. Tony Press
  28. Matty
    I thought you might like to see this portable roadside construction patent drawing. I haven't a clue if it was ever manufactured.
  29. JEFF JOHNSON
    Thanks Matty and that's different.
  30. Matty
    Jeff, another one that I think is really cool is this signal lamp. It is GPA yet is rigged so it blinks. The lamp has been designed to use as a warning light for motorists. It would be awesome to find one.
