Mostly air on my 236
Discussion in 'Fettling Forum' started by Juan, May 31, 2020.
  1. MYN
    Most of the fuel-air tubes have a round opening for the air inlet. Like in this image from OCP:
    Yours have a slot instead, Juan. Interesting. Just wondering if that could be a little too enlarged. If it is, you might try to partially block it or stuff some brass gauze for air flow reduction, between the slot and the inner tube in case you couldn't find any faults in the inner tube. Just a thought.
  2. Blueflame Canada
    Montreal Canada
    Maybe a dumb suggestion...are you sure there is an inner tube?
  3. george
    Could have missed something but I would clean it very well the take that spring in the F/A tube and stretch it slightly.
    There is one other thing to think about: there is a tube that comes off the pump barrel and "snakes" to the top part of the tank. That tube, over time, can be partly clogged. They can be a real PITA to free up! If this tube is partially clogged you should meet some resistence when you try to pump it.
  4. Juan
    I did try and it didn't work. Because pressure has nothing to do with the size of the hole.
  5. Juan
    Oh, yes, I'm sure.
  6. Juan
    Everything is clean, the spring has good strength, etc. The only thing I'm not sure if the inner tube is sealed at the top. I could see it is screwed on the external tube but I still can't guess how to remove or to tighten.
  7. Blueflame Canada
    Montreal Canada
    Is it possible that the slit we see in the tube has also cut the inner tube?
  8. MYN
    Could you find any defects or leaks in the inner tube? I hope it has not been somehow shortened prevìously. If the inner tube has been cut short, you'll get the same effect as what you're getting.
    If its threaded and not soldered, you'd be able to remove it. If it seems too tight, you might heat-quench it a little to loosen up the threads. Make sure that you remove the rod and spring first before you try this or the spring would loose its temper once heated. But if the inner tube is not really defective, don't attempt that or you'll risk damaging it.
  9. MYN
    Juan, if you happen to have a spare fuel-air pick up tube, you might to try swapping that to see if the problem persists.:)
  10. Juan
    No, and I guess it's original.
  11. Juan
    I can't figure how the tool should be.
  12. Juan
    Good idea. Let's see if a 220 fits
  13. Juan
    Well, the 220 has the same problem.
    I just blocked the air port and the lantern works fine ... obviously no quick start ...
  14. MYN
    Seems you'll need to sort it out somehow..someday. The quickstart feature's still missing. :-k
    I think the inner tube has been soldered (at least on some) and not removable simply by unscrewing.
