Nozzle Phoebus 615
Discussion in 'Fettling Forum' started by Atlan, Aug 17, 2026.
  1. Atlan Germany
    Hello everyone.
    Here I made a new nozzle and a new needle bar for the Phoebus 615. Nozzle and needle were no longer available. Unfortunately, I didn't have hexagonal brass there, so my nozzle is round. But it can be put on well with a leather cuffette.
    Greetings Michael
    Well fettled.:thumbup::thumbup:
  3. Kristof Szabo
    Kristof Szabo Hungary Subscriber
    Hungary
    Hello!
    May i ask, how did you make it?
    I also have a 615, unfortunately without a jet, and needle.
    Nice lantern!
  4. Atlan Germany
    Hall Kristof Szabo.
    I used a 6mm round rod brass. Since I was missing the entire needle rod, I made it from 2mm brass. I pre-drilled the nozzle inside 2mm except for the last 0.3mm, which I then drilled 0.1mm and ground down to 0.13mm. A nozzle cleaning nade! I inserted a needle from a 0.12 mm acupuncture needle into the needle bar and pressed it.
    Greetings Michael
  5. Camp numao Japan
    Japan
    That’s amazing.
    How did you drill a 0.1mm hole?
    I once gave up on it because the drill bit kept snapping immediately.
  6. Atlan Germany
    Hallo Camp numano.
    Please Look at the thread Petromax 834
    The Prozess is heare.
    Michael
