Optimus 930 300CP Questions
Discussion in 'Pressure Lamp Discussion Forum' started by Gneiss, Sep 8, 2013.
  1. Mildmike
    I will bring my 930 to Ashover to demonstrate.
    Looking forward to meeting you guys.
  2. David Shouksmith
    Possibly, but I think it's more likely to be that the hood hampers the airflow through the globe cage and the problem is more one of insufficient oxygen for complete combustion...
    When my 930s re-surface I'll investigate - one definitely has BMD and I don't recall ever running the other. We'll see...
  3. wd40addict
    When you put the hood on there is a distinct change in the hiss as it is presumably constricting the airflow and thereby altering the mixture. If the lamp is just a little rich this may well be enough to 'fix' it. However my lamp is so rich that only blowing in the air gap improves things.
    Regards,
    Paul
    Hello Mike and welcome aboard! :thumbup:
  5. Salar and Stove Denmark
    Denmark
    Hello
    I have several of these 930 300 CP and 350 CP and have never had problems with these lamps.
    But - a friend of mine had problems - big problems.
    After 5 to 10 minutes suddently black mantle and mixing tube was glowing red.
    We changed jet, mantle, fuel and controled the gap and vapourizer - black mantle just as before.
    Then I said - do you have another keramic nozle - and we saw the tiny holes was bigger!!!!
    No more problems with the lamp, and both nozzle
    was Optimus 250 !!!!!!!!
    Thanks for the information! :thumbup: Jeff.
  7. Gneiss
    Gneiss Subscriber
    Yes that's interesting...
    Are there alternative nozzles that will fit these lamps?
  8. Salar and Stove Denmark
    Denmark
    Yes - Petromax 250 CP
    I have more Optimus 250 nozzle - and they are
    all OK.
  9. Gneiss
    Gneiss Subscriber
    I have discovered after a lot of use at Ashover that mine can develop black mantle and how. Mine does it after several hours if I just neglect it and let the pressure drop. A few pumps to bring it back to full brightness and it burns off the black again.
