Restoring Q99's & safe starting procedure for Quick-Lites
Discussion in 'Fettlers Master Class' started by furry flivver, Jan 11, 2011.
  1. John P. JOrdan United States
    Doyline, LA
    There are instances on some of the coleman lanterns when the pressure is high enough from vaporization that the system burps pressure back to the tank. I have had several of my lanterns reach this state, especially the 220 model B-F's...
  2. Bruce Kuda
    Bruce Kuda United States Subscriber
    burlington Wisconsin at Camp Wounded Dog
    I don't know if everyone will approve of this method-- but it has worked for me for years with only one failure~~~~ Remove the Q99-- grasp with needle nose pliers and heat very hot with your propane torch-- that will give you a hotter flame then the vaporized gas-- and will burn out the carbon deposit--- you will usually get some flame from both ends from the destructive distillation of the carbon-- when it stops it should be clear -- let it cool- poke the orifice with a tip pick and you should have a serviceable q99 once again-- only with unmolested q99s ~~~~ the caveat on my one failure-- I did not carefully visually inspect when was done- it had a stress crack that blew out-- exciting time in the shop for a minute or two
